Very simple: I would like a countdown clock function that allows me to set a countdown for a length of time greater than 90 minutes (as is the current limitation).
It doesn't need to be any more complicated than changing the minute options from 0-90 as it is now, to 0-1380. That would allow a countdown from 0:00:01 to 23:59:59.
Yes, please add more time time the countdown alarm, then I would be able to time my nighttime routine for every three hours without waking the baby or my husband
I really need this feature since I have to take medication every few hours. What made me decide on the Fitbit Versa was because it had a countdown timer, guess I should have checked that it could actually do what my ancient cheap Casio can do....
I also need a timer that is greater than 60 minutes (Charge3). I have to eat every 2.5 -3 hours. I’m very surprised at the limitation. I can’t use the alarms because the timing of my meals varies.
I also need a timer that is greater than 60 minutes (Charge3). I have to eat every 150-180 minutes. I’m very surprised at the limitation. I can’t use the alarms because the timing of my meals varies.
I have been using a FitBit since 2012 and have bought probably 10 of them however, I have left the platform simply because I need a multi hour countdown timer to remind me to take my meds. I heard the Charge 3 had such a time so I bought one only to learn it won't allow me to set my 3 hour 45 min reminder! Please fix this ASAP. It's a quick patch that will bring back lots of folks like me who love the community but left cause of the lack of a med reminder.
My friends and I are in need of a timer that goes 16-20hrs. All that we can find are minute times or one that go no more than an hour. It would be great especially for those who are intermittent fasting
This should be such a basic function. Very easy software function. Regardless of what most users will use. A very common use for a timer would be to remember to take a medication. I'm sure very few people take medications in 99min intervals!
Please add a longer countdown timer. You have a huge crowd of flight attendants that would buy your product if this was available. A small software update even!!
Is there a reason this isn't a thing hour, minutes, seconds timer can be down on my 25 dollar Adidas watch but I can't do it on my 250 dollar Ionic? Seems strange to me please address as soon as possible please and thank you.
I'm desperately in search of a simple timer app that lasts more than 99 minutes and will still run even after minimizing the app. Of every timer app offered, only 3 offer timers longer than 99 minutes, but none of them will run in the background or will ring if you exit the app. It's not practical to be forced to keep a timer app open for 2 hours just to have a countdown longer than 99 minutes. Is there anything anyone can do to help?
Hi @riztotheo! Great suggestion, thanks for sharing your feedback. I've moved it into a similarrequest. Post a comment or click on the thumbs-up to show your support.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
