Sometimes when I go for a run I like to see when I'm halfway done so I can turn around, but I have to keep looking at my watch to see when it reaches my intended halfway mark. For example, let's say I want to go on a 30 minute run, 15 minutes out and 15 minutes back. I don't think it'd be very efficient to have to keep looking at your time. I think a feature should be added that allows you to set custom vibrations after a certain amount of minutes. Let's just say I want the watch to vibrate after 5 minutes, 10 minutes, 12 minutes, and 16 minutes. I think you should be able to set small "alarms" for you once the stopwatch reaches that amount of time. I really hope you put this into consideration! Thanks!
Moderator Edit: Added Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
