Hoping FitBit will make Livestrong MyPlate compatible. I've used the other apps that are compatible and MyPlate is much better, it has a wider data base on foods and more user friendly.
Moderator Edit: Clarified subject and updated label
i love how at each meal the food log shows daily counts of all items such as protein carbs, etc. but it would be even better if it had a grand total, a standard amount and if you are higher or lower. Please see my plate by livestrong. I used to log there until i met fitbit. the log there is similar to fitbit but with the totals i'm suggesting.
Fit bit has the market on tracking but is very lacking in Food logging. I used Livestrong for 3 years and thought it was OK then switched to My fitness Pal and found out what I was missing. I need to track many items about my health do to a study I am in and am required to use the fit bit and track food. I love the fit bit but the food log is lacking!! lRecipe entry like My fitness pal please! ( This allows for individual to fully understand what they are eating for nutrition). Having the bar tool to scan food would also be so helpful.
Hi everyone, and thanks for taking the time to share this product feedback about making an integration between Fitbit and Livestrong MyPlate with us. Our web API and smartwatch SDK are open which means that the service you are wanting can actually integrate with Fitbit. We’d encourage you to make this product feedback to the service and direct them to our existing API and SDK and resources such as the web dev API community. You will likely be able to email them via their contact us page or customer support, or they may have their own ideas board like this. Or encourage them to reach out to Fitbit directly. Thanks for your participation in the Product Feedback forums, we look forward to making Fitbit more useful for you.
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
