Integration with Google Fit
I'd very much like my fitbit data available in Google Fit. I use a different app for food logging, but Fitbit's step counter, sleep tracker, and aria are great.
If their data was available through the new Google Fit it would be fantastic.
Moderator edit: Added labels.
1,023 Comments
fivepointtwelve
First Steps
Intergration with Google it would be AWSOME!!!!!!!
Also with it intigrated I would make me more inclined to use my Flex more and maybe buy the new Charge.
slow_racer
First Steps
Please add it to Google fit
pyrosrock
Jogger
yes +1
im thinking if it does integrate then i will upgrade to a Charge or a Surge and will get an Aria.
otherwise i will be looking elsewhere
Gutshot
Jogger
It seems to me that it would be a pretty obvious integration.
bjroadbike
First Steps
Yes, please add integration to Google Fit via their SDK.  Their is so much potential with using your excellent hardware and tying in several other input sources to get a consolidated view with the Google Fit app.
pratster
First Steps
+1 for Google Fit integration.
miraj31415
First Steps
Want full integration with Google Fit for my android. I use Aria.
wade_county
First Steps
Please add Google Fit integration!
gregmr
First Steps
ExRoot
Jogger
Please integrate Fitbit with new Google Fit app.
genven
First Steps
Ditto the above requests! I want Google Fit and Fitbit integration.
nyakove
First Steps
I second this suggestion
megatomic
Base Runner
Please add my vote to this also. Do want.
thebrofessor
First Steps
Yes, please integrate with Google Fit  my gf and I both have FBOne and we have an Aria as well
comatose1978
Recovery Runner
So many other apps tie-in with FitBit... I dont see why Google Fit wouldn't....   Is it FitBit or Google not allowing this to happen?
exuser
Powerwalker
We of the Apple side wish you Android users good luck in your quest. Don't get too excited though. We're at 850 votes and 1500 posts with no decision from Fitbit forthcoming.
scyphers
First Steps
+1 for this feature
catlem
Jogger
I would like to be able to have my flex integrate with Google Fit
jasonbereklewis
First Steps
I love my FitBit Flex! Using this device has had a major, positive impact on my health. I've gone from struggling to get to 4000 steps a day to smashing through 10000 a day in just a few months.
I'm also an Android user and would really love to see my FitBit data in GoogleFit.
Thanks, Jason
mashimus
First Steps
+1
Google Fit integration please!
Kkemenyes
First Steps
Please allow us the ability to use Google fit. After all, we're all fitness enthusiasts and it's another way we can quantify our fitness goals, just as fitbit is intended to be used
ritson71
Recovery Runner
+1
Nodes
First Steps
+1 for Google Fit integration please, pretty please 🙂
lostprophet
First Steps
Snakeblood
First Steps
Same here. Integrate please!
