There is a difference! If you are following, Atkins, Keto, Paleo or any of the LCHF diets, you do not count standard carbs, you count net carbs (Carbs - Sugar alcohol - Fiber). There is currently no option on your site at all that allows the entry of net carbs or a field for sugar alcohol (Erythritol, Xlitol, etc) to be able to calculate this in your macros.
Diabetics use this, as well as dieters for weight loss or training.
Moderator edit: Labels
Community Guidelines
Learn the Basics
Join the Community!
Go to the Help Site
Contact Support
