I am trying to make a easy counting app, but I do not know how to make it so that when a user presses a button, say button bottom right (btnBR), I want the number to go down, and if they press top button (btnTR), the score goes up. Can anyone tell me how to do this?
You need a <text> field and a button, apply some styling etc too. See https://dev.fitbit.com/build/guides/user-interface/svg-components/buttons/
<text id="mylabel" />
<use id="mybutton" href="#square-button" y="5" fill="fb-red">
<set href="#text" attributeName="text-buffer" to="Click Me!" />
</use>
then code would be something like:
import document from "document";
const mylabel = document.getElementById("mylabel");
const mybutton = document.getElementById("mybutton");
const counter = 0;
mybutton.addEventListener("click", () => {
counter = counter + 1;
mylabel.text = `${counter} presses`;
</use>
const counter = 0;
Best AnswerWhen I threw this into a test app (after it not working in mine), I couldn't get it working. Any ideas?
Best Answer@JonFitbit solution should work (it is similar to what I am using in my app). What happens if instead of updating the textview, you print the value to console? Put this in the onButton Clicked event handler.
console.log(`The current count is... ${counter}`);
Edit: After looking again, I realized, I created the string differently. If the above works, you could try this...
mylabel.text = counter + " presses.";
It should be noted that the way @JonFitbit did it should not only work, it should be better to construct a new sting than concatenate an old one like this, but it does seem to work for me.
Excellent. I am glad it helped.
