01-23-2019 14:19
01-23-2019 14:19
We have released a web based graphical tool for clockfaces creation.
It permits to generate fully functional clockfaces for Ionic and Versa, without writing a line of code.
It can be also very useful for developer to quickly test their designs.
You can go on https://fitface.xyz to try it
FitFace Team
02-21-2019 19:24 - edited 02-26-2019 19:47
Will say that I do love the application, and have created/published several faces. Each one improving a little more in complex design.
With that being said, I am currently having an issue not with the design aspect of the site, but in the since that I cannot push any of my created or Favorited faces to the watch face. Yesterday I was able to update and change as I desired using the fitbit app. I did notice that the fitface portion of the app requested an update this morning and after that I have not been able to get it to respond to any changes for fitface. stuck on the default loading screen after swapping to a standard (not fitface) and then back.
Any suggestion on possible fix. (Utilizing Iphone, Ver. iOS 12.1.4 , Ionic)
edit:after this post I also contacted them via email. I received several responses, as this was an issue with the iOS version and that it would be resolved as soon as possible... with that being said they must have a good (great) team working together because I believe it was the following day that I received a second email stating that my issue was resolved.I tested it and was able to continue on as before (developing new user clock faces and pushing them to the actual physical device)...
overalll great product and great team from what I can tell. Thank you
02-22-2019 06:18
02-22-2019 06:18
Sorry the new feature we've introduced yesterday broke the app for iOS users. We will fix this asap.
02-26-2019 16:07
02-26-2019 16:07
This is a truly remarkable tool.
I created a watchface and that was fun to do.
Is there a list of things you plan to implement in the future?
Is there a way to dynamically change a color property?
02-27-2019 14:43
02-27-2019 14:43
Thanks for your support, we really appreciate it!
We have no public roadmap. We work everyday on the project but without pressure 😛
Sadly, there is no possibility to have dynamic color at the moment. We haven't found a cool way to add this feature yet.
09-29-2019 04:33
09-29-2019 04:33
I saw a clock face in the gallery but I don’t knop how to get in in my versa. Van anyone help me?
09-29-2019 17:39 - edited 09-29-2019 17:42
It may be set to the ionic only make sure when you do a search for the faces that you specify the device you are using
