05-07-2018 06:21
05-07-2018 06:21
I have a ScrollView that displays a list of items that use a Template Symbol. I want to build the list dynamically but not sure how to do it. What I'd like to do is get a reference to the Scrollview (document.getElementById("table"), then create each item in the list dynamically. I think JavaScript can be used to create each item but not sure how it would be done. Any ideas?
Template Symbol
<symbol id="view-item" href="#scrollview-item"> <rect fill="inherit" x="0" y="0" width="100%" height="100%" /> <text id="item1" x="5" y="50%+10" fill="white" font-size="30" font-weight="regular" /> <text id="item2" x="40%" y="50%+10" fill="white" font-size="30" font-weight="regular" /> <text id="item3" x="75%" y="50%+10" fill="white" font-size="30" font-weight="regular" /> </symbol>
View Item
<use href="#view-item" height="20%" fill="dimgray"> <set href="#item1" attributeName="text-buffer" to="some text" /> <set href="#item2" attributeName="text-buffer" to="some text" /> <set href="#item3" attributeName="text-buffer" to="some text" /> </use>
05-08-2018 11:18
05-08-2018 11:18
The items will come back in the same order every time (top down).
Another option is to use getElementById. You could do something like:
for (let i = 0; i < 6; i++) { let element = document.getElementById('sv' + i); element.text = 'Hello'; element.onclick = function() { console.log('clicked); } }
I'm working a score keep for disc golf / golf the project is in Github
https://github.com/grumpy-coders/pointy
An example of both methods are used in https://github.com/grumpy-coders/pointy/blob/master/app/screen-game.js
getElementsByClassName is used in the function unbindEvents.
getElementById is used in the function screenGameInit
Depending on what you're doing and where the data is coming from; one or the other is easier to implement. Having said that there is not really that much of a difference between the 2 approaches.
05-05-2018 04:40
05-05-2018 04:40
I have a ScrollView that displays a list of items that use a Template Symbol. I want to build the list dynamically but not sure how to do it. What I'd like to do is get a reference to the ScrollView (document.getElementById("table")), then create each item in the list dynamically. I think JavaScript can be used to create each item but not sure how it is done. Any ideas?
Template Symbol
</symbol>
View Item
05-06-2018 05:10
05-06-2018 05:10
I suggest to post your question to SDK developement Forum
05-08-2018 10:22 - edited 05-08-2018 10:23
You can't recreate items on the fly; I'd love to be able to.
https://community.fitbit.com/t5/SDK-Development/Dynamically-Create-Buttons-from-JSON/td-p/2273560
What you need to do is create an item for all the elements you think you'll need in the scrollview; set them to invisible (style.display = "none")
<use id="scrollview" href="#scrollview"> <use id="sv0" href="#view-item" display="none" class="yourClass" /> <use id="sv1" href="#view-item" display="none" class="yourClass" /> <use id="sv2" href="#view-item" display="none" class="yourClass" /> <use id="sv3" href="#view-item" display="none" class="yourClass" /> <use id="sv4" href="#view-item" display="none" class="yourClass" /> <use id="sv5" href="#view-item" display="none" class="yourClass" /> </use>
Then loop though the list of controls in javasciprt setting up there values and making them invisible.
let elements = document.getElementsByClassName("yourClass"); for (let i = 0; i < elements.length; i++) { let element = elements[i]; element.text = 'Hello'; element.onclick = function() { console.log('clicked); } }
It's a bit of a pain, but it is the only way I have found to make it work.
05-08-2018 10:56
05-08-2018 10:56
If I use document.getElementsByClassName("myClass"), am I guaranteed the items will come back in the correct order? If each of my items use: class="myClass", when I loop thru the items, will I always get item1, item2, item3... ? When I set the values for an item, it must be in the correct order in the list.
05-08-2018 11:18
05-08-2018 11:18
