12-08-2022
10:59
17:53
LizzyFitbit
12-08-2022
10:59
17:53
LizzyFitbit
I can see many are facing issue with adding cards in Google wallet . The cards that supprt in mobile not supporting to setup in Watch
It would be really helpful if there is any timelines to fix these bugs
Moderator Edit: Clarified subject and formatting
01-22-2023 10:47 - edited 01-22-2023 11:02
@Nounou78 open a case with Fitbit and make sure it is escalated.
Best Answer01-22-2023 11:09
01-22-2023 11:09
I've had the same problems but I was able to get Afib monitoring to work and one Bank card in Google wallet. On the greyed-out box page swipe up near the top of the page and it worked for me. It was simply poor coding on their part that confused me as well because there was no indication on the page to do this. My google maps still don't work right either.
Best Answer01-22-2023 11:14
01-22-2023 11:14
It is so simple in my opinion for fitbit. Google wallet is not functioning like it should.
It should have the same bank cards to use as my Pixel 6 pro phone has. IT DOES NOT!
Give your loyal customers the option to go back to fitbit pay, witch was FULLY COMPATIBLE!!!
The problem with wallet is that it wants to use an old verification method that my bank does not use anymore.
Google wallet on my phone uses the new verification method.
I think fitbit forgot to update their system.
You made a mistake fitbit! you have two options: update google wallet on fitbit or go back to fitbit pay.
01-22-2023
11:46
15:11
DavideFitbit
01-22-2023
11:46
15:11
DavideFitbit
How do I do this ?
And how do I get it escalated
Fitbit pay no good for UK residents
As none of our banks are supported so when
Google wallet became a option many of us gor excited ran out got the watch it taking the mick
They can't update a old verification system and work with the banks
01-22-2023 11:52
01-22-2023 11:52
I used - contact customer support - in the Fitbit app. I did it via the chat option.
Best Answer01-22-2023 14:49
01-22-2023 14:49
Also funny, fitbit says on this site: https://www.fitbit.com/global/us/technology/google-apps/banks
that my bank is supported in google pay.
For Netherlands ABN-Amro (mastercard)
ABN AMRO does not allow you to put your creditcard in google wallet, not on your phone and not on your watch.
The only card that ABN AMRO allows you to use is a debit card in google wallet.
So the information on the fitbit site is incorrect!
01-22-2023 16:26
01-22-2023 16:26
@toetjewat I have the same situation in the UK, banks in the Fitbit Google Wallet list that don't work.
@LizzyFitbit when are we going to get this disaster sorted out.
Best Answer01-22-2023 17:47
01-22-2023 17:47
01-23-2023 07:27 - edited 01-23-2023 07:29
It was pure luck to find this, Fitbit should really update their operating instructions.
01-23-2023 07:47
01-23-2023 07:47
I tried again today with a credit card that is supported at Google Wallet (Android). It made a bit of progresses, but it still didn't work.
After "Contacting your bank...", it showed me an "Issuer terms". I clicked the "Accept" button.
Then it showed "Processing card details...".
Finally, it said "Your card couldn't be added".
Best Answer01-24-2023 06:31 - edited 01-24-2023 06:34
After migration to Google Wallet was offered to me on Sense 2, I was able to complete the card set up and add my Mastercard from AirBank (local Czech bank) to the watch. However, today I discovered the payments did not process when trying to pay at 2 different merchant terminals. Paying with the same card in Google Wallet in my Android phone worked fine.
I tried to remove the card and add it again to the Wallet in the watch. Now the process fails - it invokes validation in the bank app, however the card does not get validated. Even though on the first try, I've received a confirmation sms from the bank notifying me about successfully adding the card to a payment app. In the watch Google Wallet app, it still appeared with red exclamation mark saying that validation by the bank was still required.
Not a smooth transition at all 😕
Best Answer01-24-2023 08:13
01-24-2023 08:13
Just got this back from Fitbit support -
"The issue will be resolved with the next update 3.74."
I am not going to hold my breath, let's see whether it fixes the issues.
01-24-2023 17:41
01-24-2023 17:41
@infinidim I just updated to 3.74. Unfortunately I run into exactly the same issue as above.
Any luck from others?
01-28-2023 06:25
01-28-2023 06:25
Still on 3.73 app version. Re-adding the card finished the other day (although it initially said something went wrong) and I finally made a successful payment after migrating to Google Wallet.
01-28-2023 09:04
01-28-2023 09:04
Still on 3.73 app, no sign of 3.74. Still got issues.
Best Answer01-28-2023 16:47
01-28-2023 16:47
I found the list of supported banks in the PDF version of the Sense 2 user manual on p62. I think this link should get you there:
Best Answer01-28-2023 17:20
01-28-2023 17:20
Best Answer01-28-2023 17:22
01-28-2023 17:22
My app still doesn't have v3.74 and it isn't an option for me yet in the Google Play Store. I've written before because I cannot add credit cards to Google Wallet on my Sense 2. I've checked the list of banks that support Google Wallet and my cards/banks are on the list so they should work.
But they don't. Even though the Fitbit app lists my existing cards from my Google account and the cards are on the approved list I just get a "Something went wrong Please try again," error message in the app from one card and, perplexingly a message that says "This card can't be be set up for tap to pay. Your bank doesn't support tap to pay with your watch on your card. Contact your bank for more info or add another card." Again, this card is on the approved list.
I've tried the suggested steps to resolve this problem. It is clearly a Fitbit problem that renders a promoted feature unusable.
So, with the long and longstanding list of complaints about Google Wallet on the Sense 2 listed in this forum, when will this problem be resolved?
01-29-2023 00:49
01-29-2023 00:49
01-29-2023 09:13
01-29-2023 09:13
Tried again today with 3.73 app and my approved JaJa card in the UK. Still doesn't work.
