12-08-2022
10:59
17:53
LizzyFitbit
12-08-2022
10:59
17:53
LizzyFitbit
I can see many are facing issue with adding cards in Google wallet . The cards that supprt in mobile not supporting to setup in Watch
It would be really helpful if there is any timelines to fix these bugs
Moderator Edit: Clarified subject and formatting
I have tried on my wife's phone and it failed on that one as well but in a slightly different way - you can go into the set up routine but it then loops....
Best AnswerThis is the response I got from Fitbit, they have no idea when this issue will be fixed.
Hi Mary,
Thanks for letting us know about this issue. We’re aware of it, but may not be able to provide a fix in the immediate future. We'll continue to monitor the situation, and keep our team informed of the impact to you and other customers. We understand that this isn't the resolution you're hoping for, but rest assured we're always working to improve our products.
We're sorry for any trouble. We appreciate your patience and look forward to getting you back on track.
ncerely,
The Fitbit Team
@Mom1951 mark sure that you have the case number and also make sure that the case is escalated.
I have done this and I seem to get updates every two weeks about how it is progressing. None have fixed it yet and version 3.79 of the Android Fitbit app has now broken the Google Wallet setup process for me and my Sense 2 and also my wife's Versa 4.
Currently I don't think that either the Sense 2 or the Versa 4 is fit for purpose. Google / Fitbit are advertising features that clearly don't work and in UK law this is a breach of the Advertising Standards Authority rules.
So I noticed something interesting ... if I go to the Sense 2 settings in my Fitbit app (on my phone), there's an option "Device Lock" at the bottom.... I'm not 100% sure what that's *supposed* to do, but when I click it, the app goes to the Google Wallet setup screen ....
This makes me think that the current problem with Google Wallet not working properly with the Sense 2 may have some connection to either the Sense 2 or phone's screen lock settings? Has anyone explored this or have further insights along these lines? I figure while waiting for the crack team of clowns at Fitbit to diagnose and solve the problem, maybe we can do some crowd-sourced troubleshooting here and figure something out....
worth a try, right?
I use Fitbit Pay so know nothing about Google Wallet problems, but just under "Device Lock" notice it says "Enabled for Fitbit Pay only". And you can use only Fitbit Pay or Google Wallet, one or the other.
If you want to learn about Device Lock, see How do I use the device lock on my Fitbit device? but I don't think it is anything like you are thinking.
Interesting... well, I recommend you do NOT change away from Fitbit Pay ... I was using that too, and after I had my Sense 2 replaced for an (unrelated) warrenty issue, it automatically got updated to Google Wallet --- which currently doesn't work. From what Support has said, it's not possible to downgrade (really UPGRADE 🙂 ) to Fitbit Pay once you're switched to Wallet
When setting up a wallet, The first step is to enable the Pin Lock. I set the pin lock for only the wallet (default is the whole tracker)
Without a wallet, there is no reason for the pin lock, and setting up a pin lock is part of the wallet setup.
From what you describe, It looks like a pin lock could be setup without setting up the wallet.
04-19-2023
17:00
16:18
LizzyFitbit
04-19-2023
17:00
16:18
LizzyFitbit
The issues:
1) I managed to put in 1 card for Google pay, but everytime I try to add a new one (which is supported by the app) the screen won't open to allow me to add another card or do anything with Google pay.
2) cannot install any other apps?? Why?? There's so many other apps supported for previous version!
3) does this watch measure body composition? Like fat, water etc?
4) can't change music!!!!
So frustrating! Feel like throwing the watCh away!
Aa for the wallet, have you tried logging out / in with the fitbit app? Clear the fitbit app cache?
You say that you have one card connected. And trying to add a new card, the next screen never opens?
For 1) it sounds a bit like the same problem we're having in https://community.fitbit.com/t5/Sense/Fitbit-app-crashes-when-updating-credit-card/td-p/5105733
Unfortunately no solution yet.
Hi Rich_Laue,
Yes I have tried doing this. I even tried uninstalling it and reinstalling the app. Its still not working. Apparently a lot of people have been having this issue so it begs me to question why on earth would fitbit advertise google pay etc when they don't have these features. It's plan daylight robbery off their customers !
I just changed from versa to sense 2 and me too facing the same issue with Google wallet on my Fitbit. I have been using Fitbit pay on versa for a few years with no issue at all. Now with sense 2, it just doesn't sync with Google wallet no matter what I did. I followed all instructions.
I'm shocked this issue has been on going for a long time with no solutions! This is soooo unacceptable!
Most of us are in the same situation with regards to Google Wallet on the Sense 2 and Versa 4.
You need to open a case with Fitbit and make sure it is escalated and get the case number so you can chase them about it.
I am also facing the same problem. I just got my watch today. And really disappointed to see that the watch doesn't work properly(Google Wallet). I'm going to return it.
What I dont understand is how Is this more expensive than the previous versions which had more functions than this watch does. It's an expensive downgrade in all honesty.
I would really like to know what is the additional amount for? Just the name sense *2*. What upgrades are there. What's different?
Agreed but I think I've found the fix for adding a card and worked in Morrisons 🙂
