06-29-2025
09:32
06:57
06-29-2025
09:32
06:57
Hello,
I would like to report an issue with my Fitbit Sense 2 device. The battery is draining very quickly (lasting less than a day, even while idle), and the watch sometimes turns off by itself, even when it has charge.
I have already followed all the recommended steps:
Reduced the screen brightness to the minimum;
Disabled all notifications and high-consumption features (such as the voice assistant, continuous monitoring, etc.);
Restarted the device;
Verified that the firmware is up to date;
Performed a factory reset;
Removed all third-party apps.
Even after all of this, the issue persists. The battery continues to drain very quickly and the abnormal behavior remains.
I would like to know what the next steps are and whether it is possible to claim the warranty, as the product is still within the legal coverage period.
I look forward to your response.
Best regards
06-30-2025 06:59
06-30-2025 06:59
Hi there, @JoelFig. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the battery of your Sense 2 is draining quickly. I understand your concern, I will do my best to help you with this!
I've seen you contacted our Support Team after posting here and they've already assisted you. If the steps that our team has provided did not work, please feel free to contact them back for further assistance. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Thanks in advance!
07-02-2025 13:44 - edited 07-02-2025 13:45
@Sebmaster , Do you have Sense or Sense 2?
07-02-2025
14:13
17:40
ManuFitbit
07-02-2025
14:13
17:40
ManuFitbit
Sense 2.
Thank you
@JoelFig , thanks for your info. How long is "in warranty"? My Sense2 will be 2 years old in 10 days from now.
Best Answer07-02-2025 16:13
07-02-2025 16:13
Best Answer07-03-2025 06:57
07-03-2025 06:57
I have all the symptoms as described above concerning battery drain. No matter what I do my Sense 2 will not last 24 hours.
07-05-2025 16:01
07-05-2025 16:01
which watchface do you have? I've completely lost control of my Sense 2. I change Watchface to force a restart. When I switched to a SPO2 watchface, it ran through battery super fast.
Best Answer07-05-2025 16:29
07-05-2025 16:29
@ionFreeman , I mostly use the watchface called "Overview"...when it works! I've been having a problem with it telling me the location or temperature result is "expired" or "loading" or other errors. Then suddenly it works again. 🙄 Anyway, when it doesn't work, i change to "weatherPro" (which also has issues) Others I use are "Watchface '20" and "Classic" I'll try to attach screenshots here
Btw, why do you need the spo2 watchface. Unlike the old watches (like my old Versa2) that needed to have the watchface open to get your oxygen level, the Sense2 has it built-in
"Class
Best Answer07-05-2025 16:40
07-05-2025 16:40
I do not need the SPO2 face. I just needed to pick a face to force a reboot. I don't see how to get back to the original one. I can't pair my pebble anymore as it's stuck in a reboot loop, so no more changing watchface for me.
Best Answer07-05-2025 16:55 - edited 07-05-2025 16:55
@ionFreeman , Ahh, I see. Did you update to the new Sense2 firmware? If so, this (your info) will be another example why "not" to update...and I have not updated as yet. Except for those few watch (location or weather) glitches once in a while, most functions work well and battery lasts 4 or 5 days. I'm really afraid the new firmware update will cause battery and other issues like you're experiencing
Best Answer07-05-2025 16:57
07-05-2025 16:57
Best Answer07-05-2025 18:43
07-05-2025 18:43
Best Answer07-07-2025 04:18
07-07-2025 04:18
yes, updated the firmware
