Hello @mtwatch, welcome to the Fitbit Community!
I'm truly sorry for the inconvenience you've experience with your Sense 2, let me suggest some steps.
For more help, please check out this article: Can I extend my Fitbit device's battery life? Please let me know if this works!
Best AnswerI also have a Sense 2 (US) which was working great (4-5 days battery life) until March 27 when it went to <1 day. That's without using the GPS, only opening the app to sync and every battery saving 'trick' they recommend. It's weird that it seems to have happened at the same time they released the new app (iOS) update that has had a ton of problems. My watch is still under warranty but they want me to send it back to them before they replace it which is completely unacceptable.
Hey there @mhouse, nice to see you around the community.
Thanks for taking the time to share all this information with us. I really appreciate the time you invest here!
I totally understand your frustration about this hassle. Please consider that as soon as you follow their recommendation, you are going to get your replacement device and be back on track.
Keep an open line of communication and your issue will be solved easily.
06:15
20:06
ManuFitbit
04-11-2025
06:15
20:06
ManuFitbit
Same. Mine is less than a year old and used to hold for a long time. Now it’s just a couple of hours. (It got worse and worse).
Same. Now I am seeing a pattern for everyone. Not sure what’s going on but about to go
@EstuardoFitbit I appreciate that there’s a ‘process’ for returns, as inconvenient as it is. I just wish there was something as robust to actually solve the problems that users are facing. It’s interesting that after this last app update Sense 2 owners are having battery issues, new and older devices. Mine went from 4-5 days, even when I was GPS tracking 3 hour hikes, to < 24 hours overnight on March 27. I’m choosing not to return the tracker at this time because I don’t believe I have a faulty device and a new one will have the same problem due to whatever app or firmware bug they introduced in 4.39/4.40 (iOS).
I’ve been a Fitbit user for > 10 yr and have paid for premium since available. Unfortunately, Google keeps pushing buggy updates under the misrepresentation of improving user experience. It took 6 months to get the lap/pace units (km vs mi) error corrected only to lose 10 years of water logs because they converted all of the history to ml from fl oz. Not to mention that removing the 30/60/90 day rolling trends in the Health Metrics made data tracking meaningless. You’d think they’d beta test and get feedback from users, but I guess the goal is to tank Fitbit and push everyone to Pixel.
Hey everyone, I'm glad to see you all around the Community!
I can definitely understand why you all think the update is causing the battery drain issues.
For those having this type of issue, if you have already tried the suggested steps shared in my first post and are still experiencing issues, please do not hesitate and click here to contact our support team. Depending on each case, they will decide which is the best course of action.
Please let me apologize for any inconvenience you have experienced due to this issue.
Best AnswerI don't know if this will work for everyone: I went through all of my app settings and decided to turn off Background App Refresh (which has ALWAYS been on) and my battery life is back to 4-5 days. I'm on day 3 of a full charge and still @ 63%. So something has changed in the app or it's interaction with iOS causing the battery drain, a refurbed replacement was absolutely unnecessary.
However, this did not come without other consequences, this is Google after all. GPS tracking in the app does not work correctly with the app refresh off. This was a problem last year (started with an update in March) they 'fixed' but seems to have been reintroduced in this new settings config.
This is the same route before/after changing app refresh settings
Wow @mhouse you got an amazing find there!
Thanks a lot for the heads-up and for sharing this great discovery with all of us.
I'm going to transfer this information to the right people so we can take that into account! Just keep in mind that Background App Refresh is quite important to avoid connectivity issues.
If you see something like that, please keep this in mind.
