11-10-2024 16:48 - edited 11-17-2024 17:12
My sense 2 will not stay on unless I have it connected to the charger. It will shut off as soon as it is removed and when it is reconnected to the charger it starts up. Every time it starts up on the charger it shows a different % of charge. Tried to reset when connected and that does not change anything.
11-11-2024 07:40
11-11-2024 07:40
@Ritt37 It's good to see you here again,
Thanks for the detailed information, and the steps that you've tried. It seems the issue is with the battery of your Sense 2 and so we can work on this together, I'd recommend the following steps:
Best Answer11-13-2024 17:22
11-13-2024 17:22
Thank you for the advice but the watch still shuts off as soon as the charger is removed. I even tried a second fit bit charger that I have.
11-20-2024 09:32
11-20-2024 09:32
@Ritt37 It's good to see you again.
Thanks for taking the time to troubleshoot your Sense 2. I'm sorry this continues happening and given this situation, I'd like to get you connected with our Support team. To do so, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further. I’ll keep an eye out for your response specifically, so please let me know once you’ve filled it out.
