01-21-2023
00:28
08:22
01-21-2023
00:28
08:22
The time doesn’t show up on my Screen! What can I do to get to show up
22:13
13:16
01-21-2023
22:13
13:16
Hi, @Okiegal65 - if the watch is not charged then nothing will show, but if you double tap the screen or press the button and you get a display, pull down the watch face to get to Quick Settings and disable all icons, except Brightness [which may or may not work anyway].
Then when you raise your wrist the display will come on.
If that is not working it will need charging and if charging isn't working see the full guide in How to check charge cable - Sense/ 2Versa 4 won't charge, won't start or blank screen
Best Answer01-22-2023 09:54
01-22-2023 09:54
Best Answer01-22-2023 10:12
01-22-2023 10:12
@Okiegal65- try another restart How do I restart my Fitbit device?
