03-07-2025 17:08
03-07-2025 17:08
My steps keep disappearing from my Fitbit. This is the 3rd day in a row that I have hit my 10k goal and later a number of my steps simply disappear. My battery is at 90%
this has been happening randomly for months. I thought I was crazy until I started taking photos so i have proof. I have reset my device. I am so frustrated!!!
my Fitbit showing 10k steps then 1500 less steps 3 minutes later
03-07-2025 21:14
03-07-2025 21:14
HI @sarcasticgirl - thanks for posting, it is so annoying and you can't fix it, you can follow this known bug here Unreliable step counting bug
03-10-2025 16:56
03-10-2025 16:56
This is happening to me too. Have you figured it out?
Best Answer04-08-2025 03:24
04-08-2025 03:24
Hello,
This is Onda from the VeSync Customer Support Team. I'm truly sorry to hear about the experience you've had with your scale EKS-L422-VUS— I understand how frustrating inconsistent measurements can be, especially when you're trying to track your food precisely.
If the measured item is moved during weighing, it can sometimes cause inaccuracies due to the way the internal sensors detect weight distribution. For best results, we recommend placing items gently and centrally on the scale platform and avoiding repositioning them during measurement.
That said, your product is covered by a 2-year warranty. If there is indeed a fault with the device, we would be happy to offer you a free replacement or a refund. For warranty support, please refer to the attached contact information to reach out to us.
We’d be more than happy to assist you further and make things right.
Warm regards,
Onda
