06-04-2024 23:46
06-04-2024 23:46
I’ve had my watch for 6 months and I woke this morning to find that one of the straps had come off - I have managed it reconnect it but am worried that it might come off again whilst I’m out - what should be do?
Best Answer06-05-2024 06:42
06-05-2024 06:42
Hello @Chardonnay2024 and welcome to the Community. There is a quick release lever that you use to release the band. It is spring loaded and you should feel a distinct click when you attach the band. I switch between different bands regularly. I alway feel for the click, then wiggle it a bit more to make sure it is snug. You can see an animation on your Fitbit app. Tap on your device/battery icon > Sense 2 > the bright pink How To Use > Removing the band. If you gently wiggle the lever with the band off, it should spring back to its original position. I don't think you can fix a broken spring, if that is the issue.
Laurie | Maryland
Best Answer06-07-2024 18:11
06-07-2024 18:11
I have had my charge less than a month it has come off a couple of times a bad design and poor quality known fitbit issues they should have let apple check the design before selling
