10-25-2020 08:29
10-25-2020 08:29
Hi Team,
I cannot find the option Exercise shortcuts neither on my Fitbit Android app nor on the online version after following these steps.
Is that option available for the sense?
If no, How can I add spinning to my device?
The option is just not there.
Best Answer10-25-2020 09:50 - edited 10-25-2020 09:52
Hi @ppaiva, welcome to the community.
On your Sense wake the screen and swipe from the right side to the left - look for the exercise app - tap on that - a list of exercises (shortcuts) will come up - scroll down the list to find spinning - tap on that. If you are still not seeing it, I suggest restarting your Sense by pressing and holding the button for 10 seconds (until you see the Fitbit logo).
The Sense already contains all of the exercise shortcuts, so it's not necessary to have to add/remove any. This only applied to older fitbits where you were limited to only 7 shortcuts on the device at any one time.
03-09-2023 23:33
03-09-2023 23:33
As you select the exercises, it adds them to the Shortcut screen; your 3 most recent preferences will be there. I'm amazed at the range of activities that can be tracked.
