For the last 5 days, I cannot get my app to stay on. It opens then immediately closes. After phone restart and checking for updates, I don't know what else to try. I have had this since December with no problems.
I wonder if you're affected by the Android issue documented in this thread:
https://community.fitbit.com/t5/Android-App/App-crashes-after-Android-system-update/m-p/4775056
Hi
Awesome troubleshooting Jaebird315
Which operating system does your phone have? IOS, Android..?
If not already done before, feel free to logout from the fitbit app.
Hope it helps
@Jaebird315Normal solutions for Fitbit App issues are:
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
or as @SunsetRunner mentioned
Or for IOS uninstall/reinstall the Fitbit App, and redo notification setup. |
Note the need to redo Notifications set up if you uninstall the App.
Of your phone has the issue @SteveH points to, your email program should also be crashing.
Please update your chrome browser which has a fix.
