12-21-2022
05:47
11:00
12-21-2022
05:47
11:00
Having problem setting up the function...it keeps stalling and unable to install.... keeps telling me to scroll down to continue...but cannot do so... what is wrong? Have shutdown the app many times still the same problem...help....
Best Answer12-21-2022 11:00 - edited 03-09-2024 07:52
Hi there, @Atsg2003. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue before reaching out.
To better assist you, would you mind confirming if you're referring to the Fitbit Irregular Rhythm Notifications? If so, please see How do Fitbit Irregular Rhythm Notifications check for atrial fibrillation (AFib)?
Hope that helps.
12-21-2022 16:50 - edited 12-21-2022 17:36
this is known problem. See https://community.fitbit.com/t5/Sense/AFib-notification-setup-gets-stuck-part-way-through/m-p/528869...and https://community.fitbit.com/t5/Sense/Irregular-heart-rhythm-notifications-prompt-is-greyed-out/m-p/...
I had it too and I opened request. It took 2 factory resets, reinstalls, and finally a video showing that "scroll down to continue" does not scroll before they would accept that it was not user error and an issue with fitbit software. Last communication from Support was 7 Dec.
"We've forwarded your case to one of our higher levels of support and once we have an update we'll get back to you.
We value your patience and time in this situation. If you have other questions, please visit help.fitbit.com."
Just as well I am not holding my breath. Oddly, it worked fine on my wife Sense (bought a few months after mine and we have same S10e phones).
Out of curiosity, what country are you from? Other people reporting this issue seem to be NZ or Australia.
12-22-2022 15:02
12-22-2022 15:02
Same problem with a Versa Lite
Best Answer12-27-2022 09:04
12-27-2022 09:04
I bought 3 Charge 5s (paired with Pixel phones).. same beef.
Lets see if they respond on Twitter:
https://twitter.com/Cowmix/status/1607782764237185027
Best Answer01-16-2023 12:09
01-16-2023 12:09
I had the same problem. After pinch-zooming for a while, I managed to get the top part of the screen to scroll. It's not the whole screen that needs to scroll down, just the panel in the upper half. Really bad UX design.
In the following video at 3:20, it's the upper panel in the outlined box that has no visible scrollbar.
https://www.youtube.com/watch?v=zTjFRnrZtro&t=204s
If you scroll down the part where the text is that says to scroll down, it scrolls the wrong part of the window. Instead scroll the text that says "How we use your information". Maybe it's also broken on wider aspect ratio displays because I'm sure I tried scrolling everywhere multiple times, most new phones have quite a tall aspect ratio.
Once you scroll that upper panel all the way down, it will allow clicking the button to move to the next page.
01-16-2023 13:07
01-16-2023 13:07
Brilliant! That does indeed work! Ok, my apologies to Fitbit - it was user error. Definitely a UI change would make it more obvious that it is only top part of screen that scrolls.
Best Answer01-16-2023 13:10
01-16-2023 13:10
Indeed, huge UI problem here! I was finally able to scroll, using one finger to hold the bottom part an another to scroll the top part!
Best Answer02-05-2023 06:09
02-05-2023 06:09
Thanks, this worked for me.
Best Answer02-15-2023 17:52
02-15-2023 17:52
Thank you!!!!
Best Answer02-19-2023 15:25
02-19-2023 15:25
Thanks so much!!! Afib runs in my family, so it was critical for me to be able to activate this feature. It was not intuitive at all and without your guidance, I doubt that I would ever have figured it out on my own. I even tried activating on the website, and had the same issue, so I'm very happy that I found your post.
