02-19-2023 02:44
02-19-2023 02:44
Is there a way to flip the display on the Sense 2 so that I can wear the watch on my right wrist without constantly long pressing the button on the side? Lifting anything heavy causes it to be long pressed and unless I'm wearing it several inches up my arm looking like an idiot, it's constantly being long pressed.
Yesterday it was long pressed for so long whilst doing a set during weight lifting that it restarted and didn't save the workout!
Basic functionality. By being bale to flip the screen, I can wear the watch with the button on the opposite side fixing the problem.
Best Answer02-19-2023 03:39
02-19-2023 03:39
Hi @AndrewHill93 That sounds like a good idea, but unfortunately it is not something that can be done. Sorry
Helen | Western Australia
02-19-2023 13:00 - edited 02-19-2023 16:31
Simpleclockpro has an inverted face. Only problem is none of the other stock faces are not inverted.
you could use it as a face when you work out tjen switch back to the one you normally use.
13:01
10:18
02-19-2023
13:01
10:18
@NellyG , Thank you for your message and help
@AndrewHill93 , A warm welcome to the Community! Thank you for your feedback and information.
As mentioned by NellyG . Flipping the display cannot be done at this time, but I found this feature suggestion.
Maybe give it a look and vote for it if your ant to support this.
