Hi @MarylisaM - besides careful cleaning, it could be a charge cable fault, and often is.
See details in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
@lynvick56 - it would seem it's the cable for you as you cleaned it.
Are the pins on your charger all out? Mine started having issues, then I noticed the pin in the bottom right (if hanging down from the cord) was pushed in. Had to contact support and get them to send me another one.
Seems to be a common issue.
