09-05-2022 11:22
09-05-2022 11:22
My Fitbit won’t charge. I’ve looked online for support. Nothing working.
09-05-2022 15:46
09-05-2022 15:46
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
20:42
10:21
09-05-2022
20:42
10:21
Hi @Pofg - often it is good to follow the instructions here How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Chat usually works via the Fitbit App, click profile photo, Help & support, Contact Customer support.
Best Answer09-07-2022 09:12
09-07-2022 09:12
I’ve been buying Fitbit’s for years now, but noticed the battery always fails just around the two-year mark. I’m currently getting 24-hours out of mine, and it’s no longer tracking my sleep properly either. It might be time to look at a different make. I’ve currently got the Sense original model.
Best Answer09-07-2022 10:23
09-07-2022 10:23
Best Answer09-07-2022 10:37
09-07-2022 10:37
@Frank3067 I have a two year old Sense that is still getting 4 or 5 days worth of battery. I use the GPS daily too. Make sure you don't have things like Always On Display and Snore Detection turned on. Those will eat up the battery.
Best Answer09-07-2022 12:48
09-07-2022 12:48
Mine won't charge either
Best Answer09-07-2022 15:21
09-07-2022 15:21
Best Answer09-07-2022 23:46
09-07-2022 23:46
I’ve done all the above. I often assume that it’s because I’m very active, but if I look back it always tends to be problematic during the extremely hot periods. It’s not been the same since the heatwave we had. It charges fully - so no problem with the charger…just doesn’t hold the charge for any longer than 24-hours.
09-08-2022
00:11
10:21
09-08-2022
00:11
10:21
Hi @Frank3067 - the seals aren't very good and it's possible your watch got moisture inside from hot days where you may sweat more, which of course can do internal damage, so the battery may drain quicker.
It can of course be coincidence with a change of features (or how they are working) or as a consequence of a firmware update.
It might not even be the new firmware but how it was updated that could be an issue.
But your symptoms seem water related. If you are within warranty you could try a factory reset (but be patient as the process is risky and may kill the watch).
Like @Heather-S my 2 year old Sense gets charged every 5+ days.
