03-10-2022 08:06
03-10-2022 08:06
My Sense is horribly inaccurate about counting floors. It gives WAY more than I have done. It gave me a floor count of 31 one day!! I don’t get it. It just started doing it. Now I’m questioning if any of it is accurate.
07-12-2022 08:13
07-12-2022 08:13
It's been a known issue for some time. I complained several times, and finally they gave me their "solution." Remove the floor count icon from your app so you don't see it. Huh.
07-12-2022 11:11
07-12-2022 11:11
Excellent solution I would say 😜 what about now removing the indication from the watch?
07-12-2022 17:23
07-12-2022 17:23
Just happened to come across this. Just to share as well.
It is the same for me. On a normal day at work or at home, even when I do not climb floors, it would show me a floor count, most often in double digits like 20+. However, when I go stairclimbing and it would show me a single digit count like 5 floors for 15 minutes when I would have done 60 floors. My old Versa counted floor reasonably well.
Highlighted this issue to Fitbit and I was told to reset, reinstall,.. nothing worked. I did not bother to follow up after that. Just ignored the flour count readings.
07-13-2022 07:09
07-13-2022 07:09
If the floor count is not accurate, why doesn't Fitbit just take it off the watch altogether until it's fixed? It's a constant reminder of a feature that doesn't work!
07-15-2022 02:42
07-15-2022 02:42
@SunsetRunner It was removed from the Charge 5 and many, many people were upset and requested it back. Can't please everyone.
07-15-2022 06:46
07-15-2022 06:46
07-19-2022 21:57
07-19-2022 21:57
Thanks. I also get way too many floors, every day. And it seems to escalate every month. 🫤Fitbit refuses to correct this, it seems. So I am switching to another clock all together now. Too bad, as I like the app.. But if you cannot trust the floors, chances are you cannot trust other datas as well.
07-19-2022 21:59
07-19-2022 21:59
Me too.. 🙄
08-23-2022 13:49
08-23-2022 13:49
If a firmware caused the inaccurate floor count, why doesn’t Fitbit release another firmware update to fix the problem????
