03-31-2022 09:09
03-31-2022 09:09
Due to the recall on the Ionic- I switched to the Sense option. The battery has lasted at the most 2 days (48 hours). I reach out and this is what I get: "stop using the options??" I would rather risk the burned wrist with the Ionic then not be able to use what I paid for!
This is a follow up email from your previous contact with regards to your Sense’s battery short life issue.
We would like to recommend additional tips from the previous chat, kindly follow the steps below:
After following these tips and steps, observe your watch’s battery performance
Best Answer03-31-2022 09:16 - edited 03-31-2022 09:16
I think that is reasonable. Turn off what you do not need/want. See where you end up.
03-31-2022 10:01
03-31-2022 10:01
@JCrass I would ask them to do a battery test and consider returning it if it fails. If you go the warranty route, you'd likely receive a refurb to replace your new watch.
Best Answer03-31-2022 10:13
03-31-2022 10:13
What is a battery test?
Best Answer03-31-2022 11:05
03-31-2022 11:05
@JCrass Support will have you turn off notifications, drain the battery, charge it, and they monitor if it's working properly.
03-31-2022 11:28
03-31-2022 11:28
Thank you. I am working on the drain down now.
Best Answer03-31-2022 11:29
03-31-2022 11:29
They will monitor???? 🍿
Best Answer03-31-2022 12:01 - edited 03-31-2022 12:02
@Clove6060 I haven't done it lately, but I had two Versa 1's fail their test. You have to set it up through support. Like ask support chat nicely if we can do a battery test. 😊
If set up yes, they will monitor.
