08-21-2021
10:19
17:07
LizzyFitbit
08-21-2021
10:19
17:07
LizzyFitbit
Dear,
my father's Fitbit Sense worked good for a half year. Since some weeks making an ECG does not work anymore.
When starting the ECG the app tells pit your fingers on he corner. This works once for just a few seconds (2 or 4), then the app says again put your fingers on the corners.
From now the app does nothing anymore. After reopen the app same. Restarting device same.
I've tried to clean the watch, factory defaults, now also new firmware, uninstall and reinstall the app. No changes.
Except now, the app does not remember (ask every time) for wearing watch left or right wrist.
This seems almost like a hardware issue.
Did anyone had same issue?
Other apps like timer or alarms remembers the settings
Thanks, BR,
Harry
Moderator Edit: Clarified subject and updated label
08-22-2021
01:08
10:56
08-22-2021
01:08
10:56
This may be a hardware issue.
Probably best to contact Fitbit Support directly. They may be able to help you confirm it.
If it is diagnosed as faulty and you have the possibility to get a new replacement from where you bought it. do that.
If you get a replacement direct from Fitbit you run the risk of getting a refurbished one which might have other faults.
Best Answer08-23-2021 11:49
08-23-2021 11:49
Thank you for your answer. I will try the Fitbit Support. 🙂
08-29-2021
18:28
10:56
08-29-2021
18:28
10:56
@DutchHarry Nice to see you around. Thank you for your report, efforts and feedback.
As the recommended steps did not helped you and as our friend Guy_ mentioned, the next step should be to have a chat with us or give us a call.
Please click here to get connected.
See you around.
