04-23-2023
21:37
16:52
LizzyFitbit
04-23-2023
21:37
16:52
LizzyFitbit
I keep loosing ECG on my sense. It works fine for month's. It is not in my apps.
Moderator Edit: Clarified subject and updated label
04-25-2023
17:03
03:01
04-25-2023
17:03
03:01
@barnett Welcome to the community forums.
Thanks for bringing this to our attention. While this is odd, may I know if you're located in a supported country? If so, could you confirm if the correct country is selected in your profile? Also, does the ECG appear installed in the Fitbit app?
In the meantime, let me recommend the following steps:
Best AnswerReboot your phone and restart your watch. Open the Fitbit app, tap your profile picture > Set Up a Device. Select your Sense 2, tap Replace Device and follow the on-screen instructions. Once that it's done, check if the ECG app permissions are enabled and make sure the assessment is completed.
Regards,
Diana
05-19-2023
15:04
03:02
05-19-2023
15:04
03:02
Hi there, @willjoe.
Thanks for joining this thread and sharing those great suggestions. I'm sure other members will also find your post very helpful.
Have a good one!
