12-12-2021
07:12
09:08
12-12-2021
07:12
09:08
The first 2 days I did an EDA scan on my Sense they logged in the app. The next 3 days never did, and my SpO2 stopped working at the same time. Everything is the newest version and I have restarted it. Nothing has fixed the issue. Water logged through the Sense also doesn't go to the app. I've only had this Sense less than a week and I already want my money back.
Best Answer12-15-2021 05:27
12-15-2021 05:27
Hi, @EcchiAngel welcome to the community, it looks like you are having a problem syncing your "Sense". How do Fitbit devices sync their data? and Why won't my Fitbit device sync? provide advice and guidance.
This article offers advice on Sp02 How do I track blood oxygen saturation (SpO2) with my Fitbit device? you do need to wear your "Sense" overnight then sync, after short delay sync again and you should see a result.
I hope this is helpful.
Cheers
Gr4ndp4 | UK
Best Answer12-15-2021 05:30
12-15-2021 05:30
I had already tried all of that and the only thing that made it start working again was to factory reset it.
Best Answer12-15-2021 05:52
12-15-2021 05:52
Hi, @EcchiAngel, you do not mention the make or model of phone you are using, most phones work well with Fitbit but some need special care Fitbit-compatible devices explains. In addition, check your Fitbit app on your phone, ensure all permissions are granted and any battery-saving setting on your phone is disabled for the Fitbit app. This last is because some phones treat the app as non-essential and put it to sleep when it needs to run constantly in the background.
Let us know how you get on.
Cheers
Gr4ndp4 | UK
Best Answer12-15-2021 05:54
12-15-2021 05:54
It's a Note 20 Ultra and all permissions were already granted and it was not allowed to optimize battery usage for fitbit. And the app and watch were both on the latest version. But after the first 2 days of owning it the eda scan and sp02 stopped recording completely.
Best Answer12-15-2021 06:10
12-15-2021 06:10
Hi, @EcchiAngel, thanks for the update, you should not be having any issues with your phone. Is your "Sense" syncing? On the "Today" screen touch your icon in the top left corner> on the "Sense" tile it will tell you when it last synced.
Let me know.
Cheers
Gr4ndp4 | UK
Best Answer12-15-2021 07:03
12-15-2021 07:03
Everything else is syncing.
12-15-2021 07:53
12-15-2021 07:53
Hi, @EcchiAngel, I assume it has successfully synced very recently, you do not mention if you synced it or left it to sync as you opened the app on your phone. A factory reset just restarts the device & deletes all your data. I suggest you talk to "Customer Support" here, use the chat facility or the phone for a prompt response. Be ready for a long conversation and note the steps you have taken before placing the call.
I'm sorry your problem baffles me.
Cheers
Gr4ndp4 | UK
