03-27-2021 05:09
03-27-2021 05:09
Hello,
I recently upgraded from a blaze to a sense and I am having issues with new device.
1.) it keep counting way too many stairs
2.) it keeps double counting workouts and when I delete duplicate it messes with stats (I.e. I’ll run 1 mile - will show up twice with different totals and stats. I’ll delete duplicate then it shows .4 miles)
3.) I keep getting my 250 hourly steps and then when I sync with my phone the hours disappear
I have read some forum responses and reset a few times but issues persist.
Any advice or assistance would be appreciated.
thank you,
03-27-2021 23:44 - edited 03-27-2021 23:45
Did you remove the Blaze from your account?
Restart both watch and phone and resync the Sense only.
Also
In Android phone Settings * Apps Fitbit Storage - clear cache [not data] Force Fitbit shutdown [though it doesn't seem to fully] Log back in to the Fitbit app
*Quick Shortcut: Press and hold the Fitbit launch icon, then App info [on some phones] |
Or for IOS uninstall/reinstall the Fitbit App, and redo notification setup. |
03-28-2021 07:33
03-28-2021 07:33
There is nothing wrong with having the Blaze and Sense connected but you do not want to use both models at the same time.
Usually a double recording is because the user has their fitbit app connected with a third party app and has started the run recording with both apps.
04-25-2021 07:31
04-25-2021 07:31
The blaze has been long sense removed from my account. The problem is I start the workout on my phone as I like to hear the distance cues in my headphones. Then since my phone is tracking workout and phone auto identified I am working out it counts 2 workouts. When I delete one it messes with the stats if other.
I have reset my watch, re-downloaded Fitbit app, re-synchromesh with no luck.
04-25-2021 07:33
04-25-2021 07:33
Hello - I have completely deleted blaze a while ago. And I do not have 3rd party apps.
thank you for insight. I have simply begun running without watch and only using phone app as the running cues and distance have the most value to me.
