08-24-2021
06:57
12:00
AlvaroFitbit
08-24-2021
06:57
12:00
AlvaroFitbit
I recently had an update on my sense. Ever since this, the battery is dying every 2 days. It dies/turns off then I charge it to 100%. I have also rebooted. Why is this happening and when it the expected time for a fix to occur?
12:01
07:20
08-24-2021
12:01
07:20
@Michelle.F Thanks for joining us!
Please try the suggestions in this help article to help improve your Sense's battery life.
Hope this helps.
07:19
07:20
08-25-2021
07:19
07:20
@Michelle.F thank you for the update. Since the issue persists I suggest you contact our Support team for further assistance. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
I'll be around.
Best Answerand then turn off bluetooth..
Hi
I've just installed the latest update and it's been fine
However on a previous update I had some battery issues which resolved in around a week
Sometimes after an update to any device be it watch or phone etc you can experience some battery fluctuations as the software settles down
I don't know why when it's the same firmware update across the board that it happens to some but not all ( I'm not an IT worker code gives me a headache)!😀
If you can stand it try to leave it for a week see if it resolves itself
If not try unpairing your sense from the fitbit app uninstall the app reboot your phone and sense install the app sync see if that helps
Good luck
