11-11-2023
03:10
06:04
AndreaFitbit
11-11-2023
03:10
06:04
AndreaFitbit
My Fitbit sense needs charging every 24 hours. I have removed everything apart from steps,sleep and heart rate. Any help would be appreciated.
Best Answer11-11-2023 04:09
11-11-2023 04:09
HI @Kathyloo - there can be several other reasons why the battery drains quickly. Try turning off the phone's Bluetooth because if the new app is having syncing problems it will drain the battery.
If the watch has suffered water ingression it will also use more battery and may get hot on the wrist or when charging and if so stop immediately.
Other things to try is changing clock face or even as a last resort doing a factory reset, which isn't without risk.
Best Answer11-11-2023 09:55
11-11-2023 09:55
Best Answer11-11-2023 10:00
11-11-2023 10:37
11-11-2023 10:37
complete a factory reset and do not add any apps.
see what happens. mine last about 3 days
