05-20-2021
06:09
08:51
WilsonFitbit
05-20-2021
06:09
08:51
WilsonFitbit
So I see some other people have posted on this problem. I ordered my Fitbit Sense on January 7, 2021, directly from Fitbit. There were some shipping issues and I finally got it at the end of January. Since receiving it, I have had intermittent charging issues. Sometimes this is resolved by cleaning the connections, other times I've had to resolve it by resetting the Sense by holding down the button for 10 seconds until the Fitbit symbol shows on the face of the watch. On a few occasions I just had to keep trying plugging it in to different sockets on my computer. However, this time it flashed "0%" the first time I plugged it in but then never charged. It won't reset using the button, nor will it work after cleaning the contacts or plugging it into different sockets. I haven't even owned this 4 months yet and I'm really frustrated with this problem. I keep my software up to date and don't know what else to do.
06-04-2022 21:35
06-04-2022 21:35
I’m on my second one and it’s doing the same thing.
06-08-2022 05:51
06-08-2022 05:51
Can you ask for refund since it's a lemon?!?
06-08-2022 07:48
06-08-2022 07:48
06-12-2022 03:31
06-12-2022 03:31
I'll be **ahem**ed! I took at look at my charging cable and it's exactly that: one of the 4 prongs is stuck inside. I guess I'll have to ask customer support for another one but at least I know the issue now. Thanks!
06-19-2022 09:30
06-19-2022 09:30
I have the exact same problem . 6 mts old. Started a month ago. I did everything it suggests and still no charge . I also have 5 diff cables for it , diff wall blocks and charging station,the whole shot . Sometimes I get lucky . Most not .Feeling very frustrated.
06-20-2022 07:58
06-20-2022 07:58
Contact customer service and they will send you a replacement. I just did. The only issue was waiting a month. Since I just received it, can't tell if problem has been resolved. Will let you know.
07-06-2022 20:07
07-06-2022 20:07
Did it help? Read that the issue? I've only worn mine 3 days to replace the versa 3 that I had 4mo and stopped charging and this one already doing this to me in less then 1week!!!!
07-07-2022 01:40
07-07-2022 01:40
Hi, @Kimjess, welcome to the community, check out the previous posts, in particular, look at Why isn't my Fitbit device's battery charging? Examine your charging cable to ensure the 4 little pins are slightly proud of the pad and free moving (they are spring-loaded) If they are not in order talk to "Customer Support" or you can buy a replacement at a modest cost from Amazon. Finally, I clean the back of my "Sense" with rubbing alcohol using a cotton wool pad and detail the pits in the back of the "Sense" with a cotton bud.
I hope this helps.
Cheers
Gr4ndp4 | UK
07-07-2022 09:27
07-07-2022 09:27
Hi there, yes. The replacement Fitbit Sense and replacement charger are working thank goodness 👍
07-07-2022 09:54
07-07-2022 09:54
07-20-2022 19:06
07-20-2022 19:06
I have been a loyal Fitbit customer for a long time and I pay for fitbit premium. I got my Fitbit Sense in January and I’ve had to battle every time to get it to charge. I just learned about the pin today, but enough is enough. It shouldn’t be that hard to charge a device. I ordered my first Apple Watch today.
07-21-2022 19:08 - edited 07-21-2022 19:09
So you joined the Fitbit Community 7 months after getting the Sense just to say you're moving on to the Apple Watch? Okay. It does have an industry-leading heart rate monitor but I do love the Fitbit sleep tracking information which is generally one of the best.
07-21-2022 21:13
07-21-2022 21:13
07-22-2022 21:50
07-22-2022 21:50
07-22-2022
22:43
17:46
07-22-2022
22:43
17:46
Have a look at Main charging tips it may help avoid charging problems in the future.
My Sense is nearly 2 years old and have to clean it every time before charging once every 5 days or so.
Unless the watch has an actual fault, often the over use of the new features, such as Snore detection, will reduce the time between charges considerably.
To get a longer time between charges have a look at the settings and features in use in How to resolve the Major issues causing short battery life.
07-25-2022 14:15
07-25-2022 14:15
I am having the very same issue! This is so frustrating!
07-25-2022 15:00
07-25-2022 15:00
07-25-2022 15:21
07-25-2022 15:21
08-03-2022 04:20
08-03-2022 04:20
At almost exactly 12 months after purchase, mine began experiencing same problem. Was there a firmware update recently? Terminals cleaned on both watch and cradle. Three different cradles used. Four different chargers used. Left charging overnight. No positive result. BTW, this is also my third Fitbit device that failed a little past warranty. Any other suggestions? I like being in Fitbit challenges with friends, but am becoming frustrated with device failures (especially right after warranty ends).
08-03-2022
04:37
17:46
08-03-2022
04:37
17:46
Hi @WolfpackDave - at a guess you have another faulty charge cable or it needs cleaning again - see instructions in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
You can get those online and check Main charging tips , especially the first one.
