03-27-2023 20:10
03-27-2023 20:10
Have cleaned the charger and back of watch but it still won't charge
Best Answer03-27-2023 23:03
03-27-2023 23:03
Hi @Marde45 - like @SamanthaB293 says - here are the full instructions for the possible causes How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer03-27-2023 20:21 - edited 03-27-2023 20:23
did you use a qtip on the back if the watch to get any dirt out of the connection points for the charger?
On your charger, are all of the prongs out? It's common for one to get stuck, which leads to a bad connection.
03-27-2023 23:03
Best Answer03-28-2023 00:57
