08-14-2022 13:57
08-14-2022 13:57
My sense is stuck on a screen - a check mark inside a circle.
Best Answer08-14-2022 19:43
08-14-2022 19:43
Hi @Debhanen13 - if you were setting it up and the firmware update had completed try holding the button fo 10 seconds to restart it, normally it's 8 but you may count fast! Also restart the phone.
08-15-2022 07:24
08-15-2022 07:24
Best Answer08-16-2022 06:07
08-16-2022 06:07
This is what they told me to do:
Don’t plug the Fitbit device into the charging cable.
Press and hold the button for about 8 seconds until the screen turns off. After the screen turns off, you’ll feel a short vibration:
When you feel the vibration, release the button and immediately press and hold the button again. Wait until the blue logo appears, then disappears:
Immediately release the button and then immediately press and hold it again, until you feel a vibration.
After you feel the vibration, release the button.
Best Answer08-16-2022 07:11
08-16-2022 07:11
