10-16-2020
06:24
18:37
LizzyFitbit
10-16-2020
06:24
18:37
LizzyFitbit
Hi everyone. Just purchased my Sense, and went on two separate runs. On both of my runs my Sense would vibrate saying that I was above my highest heart rate, I have since shut off this feature, but I got the same notification while running this morning. Has anyone else run into this issue, and how would I go about fixing it?
Moderator Edit: Clarified subject and updated label
10-18-2020
18:36
06:25
10-18-2020
18:36
06:25
Hi @k_stacks09. Welcome! It's good to see a new face in the forums.
Thanks for sharing that you got the Sense and let me help you with your inquiry. Before anything else let me explain that the Sense has two types of heart rate notifications. You can get high/low heart-rate notifications to alert you when your heart rate is outside of your high or low heart rate threshold while you appear to be inactive for at least 10 minutes. These can be turned off by doing the following:
Additionally, it has heart-zone notifications to notify you after you enter a different heart-rate zone. These can be turned off directly on your watch by opening the Exercise app, swiping to find an exercise such as Run and tap the switch on under Heart zone notifications.
Let me know how it goes.
01-18-2022 02:05
01-18-2022 02:05
@LizzyFitbit ..
...while you appear to be inactive for at least 10 minutes.
I get those heart rate notifications also when a Run session is Started or when Interval Training is Started. Sounds like a bug to me cause I am not being inactive there!
Those notifications are super annoying.
Cheers !
01-21-2022
13:40
06:26
01-21-2022
13:40
06:26
Welcome to the Community, @Grumlo.
Thanks for joining this thread, and I'm sorry for the inconvenience caused by those alerts. It seems you're not getting the high and low heart rate notifications since they appear while doing exercise. With this in mind, I'd recommend the following steps:
Hope this helps.
