05-17-2021
13:15
15:54
LizzyFitbit
05-17-2021
13:15
15:54
LizzyFitbit
I can't change the settings to 24 hour clock or to Celsius (from Fahrenheit).
i have tried the app on my phone, the app on the laptop and on the device itself (a fitbit sense), following advice given for other fitbit apparati
Best Answer05-17-2021 13:57
05-17-2021 13:57
For temp units, on phone app from 'Today' screen:
Profile Pic > SETTINGS: App Settings > Units
16:00
09:30
05-18-2021
16:00
09:30
Hi @AuntieLes. Welcome to the Community Forums. @JohnnyRow It's good to see you here and thanks for your great help.
@AuntieLes Thanks for every step tried prior to posting. In regards to the temperature units, please follow the steps described in @JohnnyRow's post and make sure to sync so those settings are applied to your Sense.
About the time format, I'd recommend the following steps:
05-18-2021 23:05
05-18-2021 23:05
hi, thanks for the clear steps...i have been to this space... units are on the settings i want but i had location on automatic. this showed me in usa instead of amsterdam. that being said, I will have to wait until afternoon to see if i get 13:00 or 1pm 🙂
05-18-2021 23:15
05-18-2021 23:15
i mixed up the instructions..... i have put the setting on celsius but it is not showing on the watch, how do i do a sync to get it there.
10:51
09:30
05-20-2021
10:51
09:30
Hi @AuntieLes. I hope you're doing well.
You're welcome! Thanks to you for trying those suggestions and just to confirm, are you trying to change the units for the skin temperature? Or is it for the Weather app on your Sense? I'm asking this as both features have their own settings in the Fitbit app. In the case of the skin temperature, please follow the steps shared by @JohnnyRow.
If it's for the Weather app, open the Fitbit app and tap your profile picture > Sense > Apps > Weather > Settings. In there you'll be able to change the units to Celsius. Once you've made the changes, go back to the Today screen on the Fitbit app and pull down on the screen to force a manual sync.
10-12-2021 20:43
10-12-2021 20:43
I did the above steps on my new Fitbit Sense, but the time is still in 24 hour mode after changing the settings and syncing. Is there something different for the Sense?,
Best Answer10-12-2021 22:14
10-14-2021
15:59
09:30
10-14-2021
15:59
09:30
Welcome on board, @MommoD. @Guy_ Thanks for your help!
@MommoD Thanks for trying the steps suggested above and I'm sorry the time format didn't update. As our friend mentioned, did you make sure to click Submit after changing the settings on your online dashboard? If you did, may I know the clock face that you're using on your Sense? I'm asking this as some 3rd party clock faces may support a specific time format. If that's the case, I'd recommend changing the clock face to one that supports 12h time format and syncing your watch to apply the changes.
Hope this helps.
