03-06-2022
11:13
14:54
LizzyFitbit
03-06-2022
11:13
14:54
LizzyFitbit
Sense : want to change clock from 12 to 24 hours.
how is it done
Best Answer@3052 This is the ONE and ONLY setting that you must do on the web dashboard. Login to your account at fitbit.com using any web browser and your same email/password. There is a Settings (gear) icon in the upper right of the screen. Tap on it, then on Settings in the dropdown. Scroll down to the Advanced Settings and there is a clock display time that you can toggle between 12/24 hours. Then hit Submit at the bottom. This is an account setting. You only need to do this once. If you replace your Sense with another Fitbit in the future, you won't need to go back and fix it again.
Laurie | Maryland
Laurie | Maryland
Also documented at How do I change the time on my Fitbit device? 2nd topic.
