04-28-2022 05:22
04-28-2022 05:22
The timer doesn't vibrate, how can I set the timer to let me know by vibrating when finished?
Best Answer04-28-2022 10:43
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
04-28-2022 10:43
Is the device in "Do not disturb mode", or "Quiet mode"? In settings on the device, vibrations are activated?
19:55
11:16
04-28-2022
19:55
11:16
Hi @suegymbunny - did you try to Shutdown your watch from the watch Settings menu? Wait at least 10 seconds for it to complete before placing on the charger to restart it and charge it.
When you press the side button to turn the screen on or off do you feel a vibrate?
If you suspect a vibration problem you can test the 8 different vibration patterns with the SimpleVibrate app, this will show if vibration is working properly.
