12-19-2022
21:37
15:27
LizzyFitbit
12-19-2022
21:37
15:27
LizzyFitbit
I’m tired of looking to check the time or my heart rate and seeing a message to activate voice assistant. I don’t want to use it. #1 I don’t want or need it #2 it’s a battery hog on an already weakened battery.
Moderator Edit: Clarified subject and updated label
23:55
07:57
12-19-2022
23:55
07:57
Hi @ZenTashi - in your watch Settings, Shortcuts assign Press & hold to something else than voice assistant, or turn it off, then the message won't appear.
It might be worth checking your settings, swipe the watch face to the right to get to Quick Settings and check that wrist wake is enabled, then there is little need to press the button, and any accidental long presses won't give you the message.
12-19-2022
23:55
07:57
12-19-2022
23:55
07:57
12-27-2022 06:52
12-27-2022 06:52
Omg, thank you, much appreciated 🙏🏾
12-27-2022
14:33
07:57
12-27-2022
14:33
07:57
Hi there, @ZenTashi. @Guy_ Thanks for your great help!
Thanks for your efforts, as well as keeping us posted. I'm glad the suggestions shared above worked for you and I'll mark @Guy_'s post as the Best Answer to help other members having the same question. Happy holidays and keep crushing your goals!
