11-04-2021
12:10
11:55
LizzyFitbit
11-04-2021
12:10
11:55
LizzyFitbit
Hi has anyone found rowing to add to your personal exercise list?
Thanks
11-04-2021 16:02
11-04-2021 16:02
Rowing isn't supported (and probably won't as it's "not currently planned" according to Fitbit) by any Fitbit device. As workaround, you can use Workout as generic type of activity and rename it later. However, if you are looking rowing specific exercise providing metric like distance, power or strokes then you won't find it on Fitbit.
11-15-2021 19:10
11-15-2021 19:10
Do you happen to know another smart watch that does track rowing?
Best Answer11-16-2021 02:28 - edited 11-16-2021 02:28
@YetiFit most of them (my one does, indoor and outdoor). Can't tell you the brand though as my posts were being removed for mentioning it.
11-16-2021 04:25
11-16-2021 04:25
Indoor rowing machines, outdoor rowing, kayaking, standup paddle boarding, and canoeing are all great exercises, Fitbit should have apps for them.
12-05-2021 13:23
12-05-2021 13:23
Thanks for the reply! I have since researched this and turns out the other two major smartwatches has really robust support for rowing. Guess it is time to ditch the Fitbit. The only thing going for it is that its battery lasts a couple of days. It's really ridiculous that Fitbit doesn't support this when everyone else does. Pretty much every major gym in America has rowers.
01-31-2022 20:48
01-31-2022 20:48
I really want this too. Just upgraded to Sense but will have to upgrade to a smarter brand device since this is important to me.
02-06-2022 04:32 - edited 02-06-2022 04:34
@laureldj Be sure to check if the other brands do auto sensing for rowing machines. I don't think that's a very common feature.
02-06-2022 05:45
02-06-2022 05:45
@eezeepee I don't know any brand (from big sports brands like Garmin, Polar and Suunto) autodetecting rowing.
02-06-2022 07:24 - edited 02-06-2022 07:24
@t.parker I didn't think so.👍🏼
Best Answer02-06-2022 12:35
02-06-2022 12:35
Both Apple Watch and Samsung support rowing as an exercise. I am not asking for auto sending, just basic support. I am more than happy to pick rowing from the exercises when I start. Rowing isn't even listed.
02-06-2022 13:47
02-06-2022 13:47
@YetiFit for that purpose, sadly, you picked wrong brand.
Best Answer04-03-2022 15:34
04-03-2022 15:34
Most of the Garmin watches do it. The best I've come up with on Fitbit is to wear a HR monitor and select Rowing after I've done my workout... all you get is the amount of time, activity and then sub in the correct amount of calories.
