02-08-2021
13:35
17:54
LizzyFitbit
02-08-2021
13:35
17:54
LizzyFitbit
Got the Sense and using it with Samsung s10. Everything was working fine until a few weeks ago the sense stopped receiving Instagram notifications. Everything is ticked in the app notifications on Fitbit and my phone, I've reset the fitbit and deleted and reinstalled the device to my phone and nothing has fixed the issue. I just can't get Instagram notifications anymore! Any help please?
Moderator Edit: Clarified subject and updated label
Best Answer02-09-2021 05:06
02-09-2021 05:06
Hi @HJS1, welcome to our Fitbit Community. Regarding the Instagram notifications issue that your Fitbit Sense has experienced, I appreciate the time spent trying to get it resolved before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. This article contains steps that you already tried but you can skip them and proceed with the rest. After this, monitor your watch and see if the notifications from Instagram work properly on your device.
Keep me posted on the outcome.
Best Answer02-10-2021 10:33
02-10-2021 10:33
Hello,
I'm having the same issue with notifications from Instagram on my Sense. I have tried everything in the article you posted but nothing has worked. I have even reset my Sense to factory settings and uninstalled, then reinstalled the Fitbit and Instagram apps. Nothing. I get every other notification except for Instagram. Any other ideas? It worked perfectly fine untill a week or so ago.
Thanks
Best Answer02-12-2021 02:04
02-12-2021 02:04
Hi,
I've tried all of these steps and it still hasn't resolved the issue. What else can be done to fix this?
02-12-2021 02:05
02-12-2021 02:05
Same for me! Tried everything including factory reset and still no Instagram notifications!
02-12-2021 02:38
02-12-2021 02:38
I think it was the Fitbit app update (Android) that screwed everything up. The timing fits for me.
Best Answer02-12-2021 02:58
02-12-2021 02:58
Makes sense! Hope they can fix it soon!
02-20-2021 03:55
02-20-2021 03:55
Good morning,
So if you have seen my other posts and posts from others, you all should know by now that nothing suggested actually works. Furthermore, I wanted to go even further with my theory (that it is the latest Fitbit app update for Android at least). I purchased a Versa 3 and obviously wiped all data from my Sense on the app, uninstalled the app and started completely over with the Versa 3. And no surprise to me, the exact same issue with Instagram notifications. I'm now back to using my Sense (after factory reset and wiping/uninstalling the Fitbit app and of course, same issue. Can you please notify whomever to please fix the Fitbit app with an update because I'm very close to canceling my premium subscription and ditching Fitbit forever. I should also mention that I'm a 5+ year user of Fitbit devices.
Thank you
Best Answer02-20-2021 03:59
02-20-2021 03:59
Don't hold your breath. Honestly, I hope so too. I'd hate to go back to Samsung over this! See my reply to the moderator about the lengths I've gone to in order to figure this out, since I can't get actual help from Fitbit.
02-21-2021 05:20
02-21-2021 05:20
Agree 100%! This needs fixing ASAP, its such an inconvenient and irritating problem and even worse when nobody from Fitbit is doing anything about resolving it! They haven't even replied to us!
02-25-2021 08:54
02-25-2021 08:54
As if 8 hours ago, the Fitbit app in Android has been updated and the issue has been fixed! So glad for that but a little communication would have been nice.... Just saying.
Best Answer02-26-2021 02:00
02-26-2021 02:00
Oh wow that's great to hear its fixed for you! I've just checked my Fitbit app in Play Store and it says last updated 28th Jan 2021 and there is no option for a new update?! I wonder why yours has updated but mine hasn't? I'm on a Samsung s10.
Best Answer02-27-2021 07:45 - edited 02-27-2021 07:46
That's odd. I would keep going to the Google Play Store and check for your app updates. Try searching for Fitbit in the store and click on the right corner and see if auto updates are on, if not, turn it on and try to update it manually from there.
Best Answer03-01-2021 02:18
03-01-2021 02:18
Thanks for your help! Followed your instructions but still not update available for me for some reason! Very odd! Guess I'll just have to keep a look out. Glad it's all sorted for you though 😁
Best Answer03-01-2021 04:35
03-01-2021 04:35
Wow as if by magic it has just updated and I am now receiving Instagram notifications! Thanks for your help, you would do a much better job at working for Fitbit then the people who actually work at Fitbit!
