08-25-2022 12:12
08-25-2022 12:12
Hi, I have recently purchased a Sense, and I only receive notifications ( texts, e-mails and WhatsApp messages) intermittently, generally after I sync the Fitbit app on my I-Phone 10. The software is up to date on both the watch ( 128.6.17) and IPhone ( ios 15.6.1)
09-04-2022 14:29
09-04-2022 14:29
when there is someone available, chat is an option. Phone or Twitter works well, too.
https://myhelp.fitbit.com/s/support?language=en_US
Support is limited by the number of representatives available at a given time and the hours of operation. Chat lines are open when they have live help.
USA: call (877) 623-4997
UK: call 0800 069 8505
INDIA: call 000 800 050 1057
IRELAND: call 01 691 7502 (country prefix: +353)
Other contact options:
USA: click
Canada: click for options
08-25-2022 16:04 - edited 08-25-2022 17:41
Are you running the app in the background?
Probably doesn’t matter but make sure you are running the most recent Fitbit app 6.33 (36648005)
Also consider downloading from the app gallery
Simplecheckup for your watch.
it shows last sync and connection test.
08-26-2022 05:59
08-26-2022 05:59
Hi Clove6060, thanks for your reply, to ensure I had the most recent version of the App, I deleted the app and downloaded a fresh copy and it is at version 6.33. I also downloaded the Simplecheckup App. It successfully completed its check and showed the last time the sync process took place. I can get notifications of WhatsApp and Text message, but not e-mails. any further help would be greatly appreciated. My phone is an I-Phone 10
08-26-2022 21:31 - edited 08-26-2022 21:34
I have the iphone12 pro max. Make sure you activate your email. I have my gmail and outlook sending notification to my watch.
Tap avatar/pic top left of today page.
Tap sense pic
Tap on app notifications
it should pull up all your apps
then swipe green the applications you want notifications from.
I’m assuming you did this and selected WhatsApp but make sure your email is green.
some screens and settings on my phone.
Hope this helps.
08-31-2022 01:18
08-31-2022 01:18
Hi Clove6060, apologies for the delay in replying, we went off on a short break. Problem resolved thanks to your very clear instructions, pictures are a great help.
08-31-2022 11:39
08-31-2022 11:39
That’s great! Glad I could help.
09-04-2022 11:37 - edited 09-04-2022 14:09
Hi, I thought I had resolved my notification problems with the help of the Forum. It worked for a couple of days but now I have discovered with the help of the " Simple Check-Up ( recommended by the forum) watch app, that my watch stops receiving notifications of text, e-mails etc when it is not syncing with my phone. I force the sync to take place and problem is resolved, all notifications are received on the watch. How often does the phone sync with the watch? However the problem keeps coming bach
k every couple of days.
The watch software is up to date and I deleted the Fitbit App and installed a fresh copy. My iPhone XR has been updated to 15.6.1.
Thanks
09-04-2022 14:29
09-04-2022 14:29
USA: click
09-09-2022 01:03
09-09-2022 01:03
Hi Odyssey13, thanks for your reply, very useful to contact numbers and online chat. My sense watch is currently syncing and I'm getting all my notifications,
09-09-2022 06:17
09-09-2022 06:17
Thanks for letting us know @agh55
