I would love the possibility to log OWN meditation sessions in my Fitbit. (Other apps than premium)
Just like you can log activitys with heart rate, etc,....
That way, you can see the effect of your mediations, and get a total overview.
Thank you!
Best AnswerWhat you can do is use some exercise category to record your meditations as workouts in the exercise app. It should be some category you don't otherwise use, perhaps yoga. Then you can view your heart rate in the exercise summary afterward. Downside, there is no easy way to look at historic record of just "yoga" sessions to see how faithful you are in your practice.
