02-08-2021
08:14
15:00
LizzyFitbit
02-08-2021
08:14
15:00
LizzyFitbit
I have had my Fitbit sense for 2 months now and it is suddenly dead. It will not turn on and it will not charge. Has anyone else had this problem? It is very disappointing since it is not very old.
04-22-2022
06:30
14:59
LizzyFitbit
04-22-2022
06:30
14:59
LizzyFitbit
Try resetting the Fitbit to the factory settings. If that doesn’t work,
then delete the app from your phone and reinstall it. --
Moderator Edit: Personal info removed
Hi @blueskysunnyday you posted your personal contact information, so please return to edit your post. This is an old thread from Feb 2021.
@blueskysunnyday I wonder how can one do factory settings when the device is dead and doesn’t respond? 🙂
Hi everyone, and welcome to our new members.
@Lekshaji Thanks for every step tried, and I'm sorry your Sense is still not working correctly. Just to confirm, have you made sure to exhaust the troubleshooting tips described in this help article? If you have but the issue persists, I'd suggest contacting our Support team so they can evaluate your options and bring you back on track. You can chat with us online or give us a call by clicking here to get connected.
@Odyssey13 and @blueskysunnyday Thanks for your help!
I'm having the same problem...I just got mine in November. It stopped one day at work- all I could see was the fitbit logo. I've tried charging it and that didn't change anything. Tried letting it die and then charge and this didn't help either. I'm going to contact fitbit.
Welcome to the Community, @Bloomienp.
Thanks for letting me know about your Sense and the steps tried prior to posting. I'm sorry you're having this experience and because the issue persists, please get in touch with our Support team as soon as you can so they can bring you back on track. Click here to get connected with them via chat or phone, and make sure to share all the steps you've tried so far.
Best AnswerI got a replacement pebble. So all good for now. I hope this one doesn't die on me soon coz i wont have a warranty after this year..
But if it does, Im switching brands for good. It would be a shame if this will be the last fitbit i own. (i previously owned 3 of them, and every member in my family uses fitbit devices too. We really did love fitbit). I still have my old Blaze which i gave to my teenager, and i found the blaze more stable than the Sense..
@Tjune- watches are neither repaired or replaced outside warranty which may be 1 or 2 years depending on country law.
A watch which is not charged will be dead.
It will need a working charge cable to charge it or it may only need cleaning, see
How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best AnswerIf it dies within two months to one year of life and when a faulty charger is not the cause, it could die soon after the warranty period too.
It is tough luck if so and indeed the Sense is an expensive model to have a life span of less than 2 yrs.. (or 1 yr depending on where you buy it from)
Still it is worth checking with another charger just in case.. before giving up on it totally..
good luck
