01-05-2024 14:11
01-05-2024 14:11
My Sense doesn't display steps or date or sleeping data and when I go into settings the writing is missing letters in every line.
Should I return to factory settings or what can I do.
Thanks
01-09-2024 08:35
01-09-2024 08:35
Welcome to the community, @Terrence22.
Thanks for letting me know about this situation with your Sense and the steps, date and sleeping data.
I was able to confirm in the system and the steps should be appearing on your Sense, can you send me a picture of what it appears, please? Also, can you send one showing the date too? So I can make sure what the situations are here.
Also, I recommend you to check this article to know how you can get your sleep score and some tips to get it solved.
Best Answer01-10-2024 11:56
01-10-2024 11:56
I’ve been having problems similar to this. All the icons are showing but there is no stats, when i go in to settings there is no options, letters, numbers etc all digits have disappeared. Can you help with this?
