07-04-2022 19:29
07-04-2022 19:29
I tried turning on and off,and a different outlet.A red 0% comes on then off but does not charge
Best Answer07-04-2022 23:55
07-04-2022 23:55
Hi @Robi31402 - unless your watch got wet, it may be a cleaning or charge cable [quite common] issue - see steps to check in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
Best Answer07-05-2022 04:15
07-05-2022 04:15
Mine has the same issue. Look at your charger there are 4 prongs. One of the four prongs does not extend out as high as the others. I called Fitbit and they are replacing the charger. Problem is they are on backorder for at least a month. Tried ordering from Amazon.....thinking at least I would have a backup. But the one I received had the same issue. Hoping Fitbit is rethinking the design and can resolve this issue.
07-06-2022 16:51
07-06-2022 16:51
Best Answer07-06-2022 21:31
07-06-2022 21:31
@Robi31402 - if you got a new charge cable, try syncing and then do a full Shutdown from the watch Settings menu.
Wait at least 10 seconds before placing on the charger to start it and charge it.
