10-03-2022
20:30
10:48
10-03-2022
20:30
10:48
Since running an update my icons and text are missing from my sense. Anything that has words is blank.
Best Answer10-04-2022 00:13
10-04-2022 00:13
I've seen a previous post where this problem was solved by restarting the fitbit by pressing and holding the button for around 10 seconds until the fitbit logo appears. As it does no harm it's worth a try.
Best Answer10-07-2022 05:41
10-07-2022 05:41
Unfortunately that did not resolve the issue. I have tried to navigate to wear the factory reset would be located within setting and that does not seem to process either.
Best Answer10-07-2022 05:46
10-07-2022 05:46
If you don't get any other suggestions here then you could try customer support via contact.fitbit.com
Best Answer10-15-2022 10:51 - edited 08-15-2025 09:11
Hello there, @Mns449. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Sense. @SteveH Thanks for your help!
If you're still having issues with the notifications after the update, please try the following:
Regarding the icons, what you mean by icons? Icons on your Sense or the Fitbit app?
Looking forward to hearing from you.
Best Answer10-15-2022 17:23
10-15-2022 17:23
Mine are there but won't open so I can reply or see more
