02-21-2022
12:27
10:56
LizzyFitbit
02-21-2022
12:27
10:56
LizzyFitbit
I bought a sense this week but not satisfied with the watch...
My watch is perfectly connected with sense controls and sense via bluetooth but i don't receive any calls on wrist..
I have done all the instructions from app but still no response
I was expecting this to be my best investment but I'm unsatisfied with the features.. sorry for such words but my experience in didn't gave any good vibes
Moderator Edit: Clarified subject and updated label
Best Answer02-21-2022 13:32
02-21-2022 13:32
Welcome to the Fitbit community.
Are you using Android or iOS and are you getting all your other notifications?
Best Answer02-24-2022 10:06
02-24-2022 10:06
I am using Android 11 and i am getting other notifications like the missed calls notifications but calling feature isn't working IT shows on app that notification service not running, a phone restart is required to re-enable notification..... I did that a lot of tims but that didn't worked
Best Answer02-24-2022 10:40 - edited 02-24-2022 10:41
Did you set up the "Sense Controls" for On-wrist calls?
Open the Fitbit app, account settings (top left corner), Sense, On-wrist calls.
Best Answer03-01-2022 21:42
03-01-2022 21:42
Yes i have done that ....
sometimes this feature works and sometimes it doesn't
06-04-2022 13:48 - edited 06-04-2022 13:50
Why is this answer marked as best answer? It’s not even an answer, the question still remains ‘why don’t on-wrist calls work reliably?’
Well, I have answer: I’ve been using the sense since last year and the ‘Sense Controls’ connection is extremely unreliable and will disconnect 99% of the time. So basically, this feature has been underdeveloped and you won’t get it working until FitBit decide to fix it!
06-04-2022 15:31 - edited 06-04-2022 15:35
Sense Controls might be listed as “Not Connected” in the list of Bluetooth devices on your phone. When you receive a phone call, the controls automatically reconnect.
They will disconnect 99.9999% of the time unless needed.
06-06-2022 11:11 - edited 07-27-2023 15:58
Hi everyone. @eezeepee and @Clove6060 Thanks for your great help!
@RealSting Thanks for joining this thread and sharing your thoughts about this feature. Before anything else, let me explain that because this is a public forum, other users might have marked it as the Best Answer. However, I understand your point of view and I've unmarked so you and other members can continue receiving help.
About your question, as our friend mentioned, the Sense Controls will connect as soon as you receive a call. However, it might remain as not connected the rest of the time to prevent the battery from discharging. If you haven't done so, I'd recommend reviewing this help article which explains more about this feature and some troubleshooting steps to get it working correctly.
