Hi, I had a Sense, which died, and I said several times here I was done with Fitbit, but FML, it might be the right answer to my problem to get a replacement Sense.
If I switch back and forth between Android and iOS, like I use my Surface Duo during the week and my iPhone during the weekend, and I either don't care where my health history is synced or it only needs to be synced on one of the two, can I easily change it back and forth between the devices? Only one of them needs to be connected at a time, but so I'd like to get notifications from my iPhone when it's in use and from my Duo when it's in use.
It seems like basically this comes down to Garmin and Fitbit and I did like my Sense, and I have all the accessories, so that I could possibly just get a new watch body, like on eBay, for cheap. I just didn't have two phones before mine died so I don't know for sure this works.
Hi, @skeet5! Your data are synced with your account, so as long as you're logged in on both you shouldn't have any problems. I have both an iOS and Android device with Fitbit on both and haven't noticed any issues with connectivity.
MakMak | Community Council
Best AnswerHi, @skeet5! Your data are synced with your account, so as long as you're logged in on both you shouldn't have any problems. I have both an iOS and Android device with Fitbit on both and haven't noticed any issues with connectivity.
