02-10-2021 08:35 - last edited on 09-09-2021 20:01 by LiliyaFitbit
I am in Canada. ECG app was just released few days ago and I was so excited to try it. But I couldn't figure out why it does not work. App keeps saying "Set up on Phone, open your Fitbit app and go to the Discover tab. Find Assessments & Reports." then click GOT IT.
I have been doing this "open your Fitbit app and go to the Discover tab. Find Assessments & Reports" many times, but every time I open the app in my watch, it keeps asking me to set up on Phone.
What else do I need to do to make it work?
Now when I go to Find Assessments & Reports >Check your ECG Health and Rhythm Assessment, it indicates that I haven't taken the assessment yet. How can I take the assessment if my device doesn't work :'(
Please help T_T
02-10-2021 08:41
02-10-2021 08:41
It sounds like you're stuck in some kind of setup loop.
You might want to try resetting you watch and removing and reinstalling FitBit on your phone.
Let us know if that fixes it!
Pixel Watch, Aria, Pixel 7 Pro, PC
02-10-2021 08:41
02-10-2021 08:41
02-10-2021 12:57
02-10-2021 12:57
Thank you, Ray! It worked! After resetting everything and installed again as if it was a new device and now it is working properly! I am so happy!
Best Answer02-11-2021 14:04
02-11-2021 14:04
I’m in Canada. I’m experiencing the exact same problem you describe!
02-11-2021 14:05
02-11-2021 14:05
I’m in Canada too and having exact same problem you describe.
Best Answer02-11-2021 19:59
02-11-2021 19:59
Hi DonRW. After resetting and installed everything again, it works perfectly.
Hopefully it will fix yours too.
Best Answer02-12-2021 05:59 - last edited on 08-25-2021 16:58 by LiliyaFitbit
Thanks but doesn’t a reset wipe out everything on your watch? When you say reset do you mean a reset to factory settings?
Best Answer02-12-2021 06:42
02-12-2021 06:42
yes. Go to setting on your watch then you will see "About Sense" click that and you will see at the end Factory reset.
Best Answer02-12-2021 06:45
02-12-2021 06:45
It's okay to factory reset your watch. As long as all your stats were sync on your profile. You will just have to install again on your Fitbit account like it was new. I know it is kinda annoying to set up everything again but it solved my problem.
Best Answer02-12-2021 06:51 - last edited on 08-25-2021 16:58 by LiliyaFitbit
But how do all your original settings get back?
Best Answer02-12-2021 08:04
02-12-2021 08:04
I did set it up manually again.
Best Answer02-22-2021 22:20
02-22-2021 22:20
No, you do not need to factory reset. Just uninstall and reinstall the app on your phone. You will not lose all your data.
Best Answer02-23-2021 00:36
02-23-2021 00:36
I am having the same issue. Already uninstalled and installed it again but the behaviour is still the same. Does anyone have any other tips?
02-23-2021 05:14
02-23-2021 05:14
Restarting my Phone and the Sense worked for me without resetting anything
02-23-2021 05:23
02-24-2021 06:41
02-24-2021 06:41
Hi ftalita.
For some sense user, they did not have to reset their watch, however that did not work for me as well. It only worked after resetting my watch. Maybe you can try to factory reset your watch as well.
02-24-2021 11:19 - last edited on 08-25-2021 16:58 by LiliyaFitbit
Thanks everyone. It worked after multiple attempts of turning the phone on
and off and uninstalling and installing back.
Thanks
Best Answer05-22-2021 13:01
05-22-2021 13:01
How is this a solution?!
05-22-2021 13:38
05-22-2021 13:38
Best Answer06-23-2021 04:41
06-23-2021 04:41
For those of you who have done a factory reset and still do not see the ECG app when you swipe left on your sense, this may help you. In the Fitbit app on your phone open your profile and find the Sense icon and click on that. Then click on apps. Look for the ECG app in your list of apps. There may be a pink button to the right stating update. Click on update. Scroll down for ECG again and watch it until the app is updated. Now you should see the ECG icon when you swipe left on your sense watch screen. This is what work for me
