06-02-2021
09:54
14:34
LizzyFitbit
06-02-2021
09:54
14:34
LizzyFitbit
Update 6/14/2021:
This update should now be available to all customers! If you have any difficulty updating, make sure you are following the directions in this article, and then provide as many specific details as possible in your post so that we can assist.
We’re excited to announce that a firmware update for Sense will be available soon! Some of you may already have this update available - if you installed it, let us know what you think!
If you don’t see the update yet, that’s expected. Check the Fitbit app in a few days, and you’ll see a message when you can install the update. We expect everyone to receive the update in the coming weeks. We appreciate your patience while we get this update to all of our customers.
Did you know that we gradually release our updates? We do this to make sure everything is working just right for you. Sometimes we find an issue and it might take a little longer than expected for everyone to get the update. While you might see suggestions on how to “force” an update, we ask that you don’t try any of these workarounds. Most of the time the update won’t be available and you can lose data or encounter other difficulties. The best way to get the update is to be patient and wait for the update banner to appear in the Fitbit app.
WHAT’S NEW AND FIXED
You can find release notes here.
HOW DO I UPDATE?
Step by step instructions for updating your Sense can be found here.
If you run into any trouble updating, review these troubleshooting tips.
WANT TO TAKE A DEEPER LOOK?
Check out our blog post here.
We’re interested in hearing your feedback on this update! Let us know what you like! If you encounter unexpected behavior during or after your update, please post the details below.
06-16-2021 14:59
06-16-2021 14:59
06-16-2021 15:05
06-16-2021 15:05
Best Answer06-16-2021 15:23
06-16-2021 15:23
Same issue. Went through all of the troubleshooting guides - lost the watch face (which I paid for, can't remember the name, and isn't listed under my faces), and still don't have notifications. Anyone have luck getting them restored?
06-16-2021 16:22
06-16-2021 16:22
Best Answer06-16-2021 16:22
06-16-2021 16:22
Did it all! Still not accepting a charge.
Best Answer06-16-2021 19:48
06-16-2021 19:48
Same. Spent all day rebooting phone, watch, turning settings off, on, factory reset twice. Then finally googled and from what I'm reading it's the update..... And apparently there is nothing we can do? They better update this update fast I'm pretty angry right now.
06-16-2021 20:17 - edited 06-17-2021 09:37
In contrast to others who replied earlier, my notifications worked for a few days after the OS 5.2 update. They stopped working from last 3 days (may be a hot fix broke it?).
This update was supposed to fix the infinite number of problems Sense had, instead it introduced new issues. Strangely, after the 5.2 update the sleep tracking always scores me above 80, even if I didn't sleep well at all. This was not the case before the update, as well as with my Charge 2.
I feel like I'm wearing a dummy metal piece on my wrist, which has the mighty potential to show time and I can change the clock face by long pressing the screen 😂
06-16-2021 23:09
06-16-2021 23:09
BAD… very bad…
to receive phone calls (wrist calls) I do the set up, go to Bluetooth, sense controls and pair... Got it Sense says all ok!
2 minutes later I'll go again to Fitbit app to check the wrist calls, and says that I need to do the set up... again!
I'll do it again, sense controls, pair with the code, says ok and ready to receive calls... I go to the Fitbit app to check the notification, and when press the wrist calls says again that I need to do the set up...!!!!!
This only happen since I've updated to 128.5.38!!!! With the previous version never happened!!!!!!
Best Answer06-16-2021 23:11
06-16-2021 23:11
Better do a factory reset and with luck will update to the late version
Best Answer06-17-2021 04:50
06-17-2021 04:50
Anyone notice a change in the counting of Steps since the update to the new firmware?
It may also be due to the Android Fitbit App update to 3.43.
Steps now seem to be under registering.
06-17-2021 04:54
06-17-2021 04:54
Best Answer06-17-2021 05:11
06-17-2021 05:11
A new feature is in the Clocks App.
The name of each clock is shown and scrolling direction is changed. Quite useful.
Best Answer06-17-2021 05:58
06-17-2021 05:58
Sp02 not fixed on my device, but was included in the "whats new and fixed" doc.
Best Answer06-17-2021 06:23
06-17-2021 06:23
@ScottHahnMN Did you swipe left on the watch till you get to the Today app, click on it and scroll to Edit at the bottom and enable SpO2, and save changes?
06-17-2021 06:29
06-17-2021 06:29
All that does is add/remove Sp02 from being displayed in the today app. Sp02 metric has always been displayed but with no data.
Best Answer06-17-2021 06:33
06-17-2021 06:33
@VetEdUASF wrote:Did it all! Still not accepting a charge.
Take a look at the charging cable and make sure all the pins are raised. None should be flush with the connector.
Best Answer06-17-2021 06:34
06-17-2021 06:34
@ScottHahnMNIf you aren't seeing SpO2 in Health Metrics check the following article.
Best Answer06-17-2021 06:35 - edited 06-17-2021 06:37
reply makes no sense for sp02
Best Answer06-17-2021 06:40
06-17-2021 06:40
@ScottHahnMN if it's showing "no data" have a read in the article of the relevant requirements to be fulfilled to get the data to show.
06:43
16:52
LizzyFitbit
06-17-2021
06:43
16:52
LizzyFitbit
Ive been through all of this a hundred times with fitbit support and have a separate community thread....
https://community.fitbit.com/t5/Sense/Sense-Sleep-and-Temp-Not-Working-Opened-May-16-2021/m-p/484562...
Moderator Edit: Personal info removed
